Fan Pulley
NiceFishEh
Ontario, Canada
Hey guys:
Trying to install a shroud on my 340.
Removed the 4 bolts that run through the flange of the clutch fan, which goes through the pulley, that attaches to the water pump.
What else is holding it on?
Rust! :)
Seriously, The shaft on the water pump centers the pulley and fan clutch and it doesn't take much corrosion or crud to make it hang up. Some "light taps" with a hammer should loosen it up.
Thanks dgc
It was rusted alright!
I used an old sharp wood chisel between the pulley and fan flange and slowly spread it apart while turning it.
This time it's getting anti sieze.
Thanks again
