Jofis
Can anyone tell me what the difference between the 1967 and 1968-69 fan shroud on a small block barracuda is? I see you can buy the 68-69 every where but not the 67. Is it able to be modified? Does anyone have one??
So technically I could use the 68-69, I could get a bigger fan if needed. Im assuming it will bolt to the same radiator mounts.The 67 has a smaller fan cutout if I remember correctly.
Are you also saying that a 68-69 would work just fine as well? Champion radiator, good lead I will check that out as well.Yes. I ended up picking up a 67 shroud for my champion radiator because it was the first one I found at a decent price. I didn't realize it was so special, or else I would've though differently about cutting it up and modifying it. I had no idea the circular hole was smaller, until I went to install it. Ooops. lol
