[WANTED] Fan shroud wanted for 1966 valiant with a 318
copralite
New Member
oregon
Rating - 0%
0   0   0
Hi , i need a fan shroud for 66 valiant with a 318 , stock 6 blade fan , nd a champion aluminum radiator. Thanks!
i don't think there's any support for OEM shrouds on that type of champion radiator.
most all of those are sold with the idea that you're going to run electric with an integrated shroud or something aftermarket.
if that does have holes on the side rails for mounting post up the measurements and maybe we can find something that'll fit
Hello
I have a 66 Dart I recently purchased that has an aluminum radiator and a shroud made by a company called wizard cooling. I will attach a few photos. Mine is not for sale but there are things out there.Sorry I cannot get photos to load it is saying images too big.
You really should install a spacer between the fan and pulley. I've seen metal fatigue/cracks as a result of not using one. It would help get your fan a bit closer to the radiator too which will also help with your cooling.
Good call. I’ll pick up a spacer
Install a spacer and buy a universal shroud on line, it bolts on thru the core, I only have the upper part installed and it does great
When you say the “stock fan”, do you mean that it has the original 17” fan? Most all Mopar fans are 18”, but the early cars had 17” fans, which make finding the corresponding shrouds hard to find and pricey.
Probably gonna need to fab somethin up.
That's what I did, and it helped tremendously.
Made from a 78 318 d100 truck shroud, cut it down the middle, but my aluminum radiator has the provisions for a bolt on shroud.
66 Plymouth Valiant
