Fan shroud
leblanc
member 2883
Dieppe, New Brunswick, Can.
This year I decided it was time for my Dart Sport to get a fan shroud but before I start I would like to see some of yours and I would like to know how you fastened the whole thing together.
My rad measures 22" X 19" and it is 2" from the fan blades (mechanical...driven by engine)
Did you ever consider making your own out of aluminum? Good way to insure that it fits properly.
are you going to use electric or mech. fan? if it is mech. that easy start with some steel rod make the base that will attach to the rad. then make the round part for fan to fit in to. take for rods and hook the base to the round fan then make sheet metal pannels and fill in thethe spaces. yes i know sounds easy enough but it is not that bad
