Fan shroud
CRUZE 418
Illinois
Guys, I will soon be into the throws of figuring out my cooling system. Would like to know what this Chrysler part is for. #2998324. Fan shroud , is for a 22" radiator.
It's not in my '69 parts book
It was in my '69 340 Dart when I bought it. It was installed upside down on a basterded 3 - half in. row radiator , fixed 7 blade fan, aluminum water pump.
It is for a slant six A body with a 22" core and A/C.
2998325 is for a small block V8 A body with a 22" core and A/C.
A quick Google shows it as a 1970 Dart slant 6.
Oops, Veryfastdart beat me to it.
Guess that I am sorta back to square one. Trying to figure which way to go with my cooling system. '69 or '70. Radiator, water pump, fan combo. Or, as Monty Python used to say, " And now, for something completely different ".
I playing with the old space issue. Seems like I read somewhere that the '69 cast pump is 1" shorter? The radiator inlet/outlets are different. Wanted to go with viscous drive fan, shroud combo. Don't know if this slant six shroud would work with a '69 Radiator. I would have to change my water pump pulley.
Yup, this thing is going to get sticky. I can start with the way it was before my engine work. If it cools, I will start again from there.
Thank you all for answering!
69 and back water pump is shorter. About an inch sounds right. I just did that conversion.
