Viceroy125
What would be the best swap parts for a 318 without having to changing other to no other parts at all?
If you change the cam your also going to need to change/upgrade the exhaust (either to 340 manifold ($$$) or a set of headers from Dougs or TTi). Also what year 318 you working with? (If it is pre roller block I'd recommend a whiplash cam from Hughes).
Since you weren't very specific at all about what you want to accomplish all I can do is guess your wanting more power. So with that in mind put dual exhaust on it. 2-1/4 pipes. Preferably mandrel bent. Summit has a deal on it for A-bodies. The 4 barrel and intake swap 1970Duster recommended is good too. Use an Edelbrock performer and either a 600 Holley vacuum secondary or a 500 or 600 Edelbrock. Put one of those Mutha thumpers in with no other mods and you'll throw what little power and fuel mileage you have out the window. Putting a big cam in an otherwise stock engine is one of the biggest mistakes a lot of people make. It may sound nasty but when you get blown away by a Prius what have you gained?
