i’ve got an underdash Fasten Seat Belt warning light that when connected to the appropriate wiring from a timed delay relay would light up for whatever the time delay is set for then go off. I’ve seen these advertised for A/B and E Bodies so they should fit anything from early A’s to later A’s, and B/C/E Bodies equipped with the timed delay relay - usually found in A Body map light harnesses. The Bezels match the emergency brake reminder I have advertised in another thread as well as the early 70’s reverse light reminder. $30 shipped from 23657
