bad440
everything,all the time..
damn! thats sweet!
I play with nitrous just a little :-D
I run a 150 shot on my 68 340 with no issues at all. System I use is the nos cheater. I also have a nos sniper set up 150 shot on a built sbc in a vega with no issues. The cheater set up has a hi flow bottle valve, bigger solenoids and brackets to hold the solenoids. Just a much better kit.
nice louis,this will be educational.maybe we should start a what to do and not do thread....I just bought a Cheater 250 kit and I will be purchasing a 150-600 Fogger. I'm going to hit a 410 all forged stroker, solid roller cam with 2 systems. A 150 out the gate on the cheater and have the cheater shut off and the fogger take over at the 1-2 shift with a 250 shot. Should be fun. This is a 9:1 motor. The main fuel system will be pump fuel and the secondary fuel system will be a 3 gallon fuel cell filled with 110 for the NOS Fuel Solenoids.
The motor is already built and I have everything. The only thing I need is the Fogger so I can start the plumbing on the intake.
thats what i'm talking about!some guys on here have some trick setups nice to learn from them.There are quite a few members here that have done some crazy stuff with NOS. I have talked to a few of them. Sounds like a good idea on starting a New Thread. Maybe even get a New Forum just for NOS??
maddart, Mine has 30 over forged pistons, factory bushed rods, forged crank. 915 j Heads 2.02 intake/1.6 exhaust. Not sure of the cam specs. Mine is set up with a wot activation switch. I run a 4 speed with 3.55 rear
For fuel have a 3/8 sending unit to a holley blue pump with a single 3/8 line to the front. 1 regulator for the carb and 1 regulator for the nos solenoid I think set at 5.5 psi. This might not be the exact right way to do it but I have run like 10 bottles in my car over the years with out one issue. I also don't hold the nitrous 1st-4th on a 1/4 mile.
Yea stock rockers and push rods up top. You would never know it but I can hit my 6800 rpm rev limiter with ease.
2 fogger systems ? How much hit, when do you hit it and how are you controlling it? 600"+ ?. Very nice!rayer:
both kits have a 300 shot in them. I use my maga 400 throttle stop timer to run the system. it's set up to come on .030 off the line and it's on for 6.5 sec. I use to run super comp with it. all I will have to do is set the 2nd timer to come on for the second stage. it has a wide open throttle switch on the rear carb that will shut the system off if I have a problem. I have some more pictures of the motor and my car that it's in if you want to see it. thanks wes
