Hi all, just trying to work out the plan for my instrument panel in my 66 Dart. I've come up with a design I like, and two variations on it.
The basic idea is to match the rest of the dash, so the top black section will be concave, and the bottom aluminum section will be a 3/16" plate laid in front. The gauges would be inset at the top where the curve is, and more or less flush at the bottom. See the cross section to better understand. The Fratzog in the middle will be a cutout to let the black show through.
The top section hold the gauges will be formed from mild steel and exhaust pipe to hold the gauges. Welded up and grinder down smooth. The aluminum trim at the bottom will have a bevel on it's edge.
Which do you prefer? Any thoughts on the overall design?
