Fender Removal?
Be easier taking the bumper off. On my 66 Valiant I pulled the bumper supports at the frame, 4 bolts and the whole thing came right off (or you can remove the front bolt on each side, loosen the rear ones and it will hang/swing down). My car also had a lower grille filler and bumper filler that bolted to the fender, so if you have a 66 pulling the bumper would make it easier.
I believe those bumpers sit real close to the fenders, Its only 4 bolts. Pull the bumper.
