Fender Tag diff code is ?
SCOTT EVIL
Member
Hello, I cant tell which code is for the rear diff. 1969 Valiant post car.
The fender tag reads:
END
A01 A14 L31 M21 M33 V1X
Y3 Y3 L2X X9 627 132294
E31 D31 VL21 D9E 166337
If you know which code is for the diff and what diff it is, that would
be great.
Thanks, Glen
These guys are right, but did you know that car is a spring special?? A little extra frosting on your slice!! Geof
Many thanks for the information. I guess I was hoping it was like the tag on a 1968 that gives the diff information.
I found the car at the Pick Your Part in Wilmington, CA. It appears to have been one of the Stimulus program and had the green paint sprayed on the engine to show it had been destroyed.
How sad, a V8 post car with no rust out, appears to have the heavy duty suspension w front sway bar. A split bench and column shift TF. Must have had a good ratio 7 1/4 because that was taken. I took the suspension to put on my 68 Dart post slant.
This is the third post car at that yard in 2 months. Must be the economy killing the extra cash everyone used to have for the hobby.
Thanks for your answers!
