Fender tag help
nuttyprof
York, Nebraska
Is there someone here who can interpret a fender tag for me? This is on an 80 Volare (F body) but I figure I'll get more help here than anywhere else!
Tag reads as follows.
N88 N98 R31 22 END
G01 G11 H51 J26 L83 N37
SC2 U 6 D52 C12 C15
SC2B2B2 000 425 DT5261
E24 D34 HL45 CAF 215468
Not a lot out there on F bodies, I think some of those codes probably are the same as A bodies. N88 appears to be Cruise Control if your car has that option.
I did find the following link that decodes N98
http://mopar.tamu.edu/pipermail/mml-test/2003-September/028590.html
N88 N98 R31 22 END
SC2 U 6 D52 C12 C15
Upon further research everything you need to know is here:
http://www.forfmjbodiesonly.com/classicmopar/showthread.php?966-vin-decoder
Go down the page until you see the order code sheet. I have interpreted your tag below
N88 Electronic Speed Control
N98 Catalyst Less ESA
R31 Radio AM
22 Rad
END
G01 Rear Defogger Electric
G11 Tinted Glass All
H51 A/C
J26 Rear Window Washer
L83 Deck Lid Gate Ajar Light
N37 Catalytic Exhaust System
SC2 Frost Blue Metal
U 6
D52 2.94 Rear Axle
C12 Deluxe Seat Belt System
C15 Special Sound Insulation System
SC2 Frost Blue Metal Exterior
B2B2 Just guessing blue interior
000 425 DT5261
E24 225 6 1 Bbl
D34 Std Duty Automatic
HL45 Volare Low Price 2 seat Wagon
CAF 226 ?? Newark
215468
