Fender Tag Snags
scott2810
Member
northern,NY
I just picked up a 69 barracuda and have most of the codes figured out, but some i cant find anywere. the codes are G33,X9, and P9B. This car was a $50.00 throw in with some other mopars i bought off a buddy. The car is a red 340 4 speed fastback with white stripe. It needs some TLC but well worth it. Any help would be greatly appreciated. thanks,scott
Thanks a lot CrackedBack, i will double check the P9B, but im am almost positive thats it, its one of the bottom codes on the right of the tag before the sequence numbers. ill check again, thanks a bunch!! scott
I just picked up a 69 barracuda. This car was a $50.00 throw in with some other mopars i bought off a buddy. The car is a red 340 4 speed fastback with white stripe. It needs some TLC but well worth it.
:shock:
You got pictures?:happy1:
