fenders
Well Muller. Since no one is going to respond i will give it a try. the finders will bolt up to the 72 but you will also need the hood and grill. Godd luck and I hope others will post if what i say is wrong. Which I hope is not.
The body lines will match at the door but it will not match at the front so like HemiPar says you will need to change the whole front end. The fenders you need are '72 only because of the side marker lights, but 70' and '71 are the same fender except for the side marker so they will also fit if you don't mind a different side marker.
Chuck
