35regal
- Joined
- May 18, 2008
- Messages
- 404
- Reaction score
- 2
i recently bought this older fiberglass hood for my 67 cuda, after getting home and getting it bolted up and adjusted the best i could i wasnt happy with the fit, my car will never be a show car but im trying to get the panels to fit as well as possible, i didnt take a before pic, there was way too much gap back at the cowl area, i gave it some thought, and i know there is several ways to fix this . this was the easiest way for me, i bought a strip of plastic drywall corner bead, i cut about 1 inch slice in every 1-2 inches in the radius, i took my hand held grinder with a flapper style sanding disk,and removed a layer of i guess gel-coat in the area the corner bead was going to lay, actually the part i grinded was alittle bigger than the corner bead so i can get a good and smooth transistion of fiberglass resin, to get it mocked up i used pop-rivets and a small driil and drill bits , i drilled about 15 small holes thru-out the raduis and strait areas and placed the pop-rivets in to hold the corner bead down, right before the fiberglass resin dried i pulled the rivits out, you have to be carefull when doing this so you dont upset the corner bead, i had to grind a couple rivets out -then refill the small area with resin again. if i had to do it again, i would of tried doing the front of the hood instead of the back of the hood, the front is straighter. hope this helps someone. p.s anyone interested in the hemi scoop? its 5-6 inches tall.
