It's fine!!Generally not want you want to see after sticking a finger in your rear end. But hey, it needed a gear change anyways.
Seriously though, that sucks. At least it didn't go BOOM!!
Wow, yikes. 8.75 or 60 ?
Did you pull both axles out of it? I’d be surprised if one of em ain’t broke. Hopefully not and just a diff rebuild will get it back going.
Interesting. I have some parts, and a housing. Let me know if I can help.Both axles out, either my eyes are bad or the splines were twisted in the slightest bit but not broken. One axle had a ton of end play, bearing on the other feels a bit wonky spinning it so I bought axles anyways. I’ll look closer at some point this week. Both tubes have the fancy metal paste in them. Probably be pulling the center in the next few days and then the housing.
You predicted this back in 21.Cmon now, you know itll destory the trans or rear-end before that ever happens.
What sure grip unit is in that diff?
Sometimes it’s painful being right. Spool in it.
My guess would be pinion bearing and race. You swapping ratio now?
That is a huge change. How much mph did it pick up?Hyguard dropped my converter slip from 35% to 3% at 1200 whp.
Thanks buddy.Congratulations on the engagement!
That 10” if its like mine it will go probably high 3’s low 4k with you hp on the brake. Mine is 4400 when I let go and the dump valve closes.
Hyguard dropped my converter slip from 35% to 3% at 1200 whp. So I am not what that guy is talking about.
It was really. It picked up .3 and 9 mph in the quarter. 8.77 to 8.43 and from 154 to 162That is a huge change. How much mph did it pick up?
Wow!It was really. It picked up .3 and 9 mph in the quarter. 8.77 to 8.43 and from 154 to 162
Holy ****!!! Real significant!!It was really. It picked up .3 and 9 mph in the quarter. 8.77 to 8.43 and from 154 to 162
That doesn't look bad. I've seen a lot worse.Forgot how heavy these things are when you’re laying on the ground. Glitter everywhere in the rear end. That’s a +/-100 mile gear set. Bearings all appear fine. I know more when it’s apart.
It was setup by someone that’s been doing it for about 100 years. Did a ton of other local cars. I won’t say it was or wasn’t properly set up as anything can happen and I’m certainly not a diff guy.You sure the diff was properly set up? That's a bit of magic to me. One of the few things I tend to send to a shop that I trust.
Hows the ring gear look? For it to stop turning one wheel it would have to have lost the splines on the axle or spool. I have seen axles not have hardly any engagement and then break when a good amount of power is applied.
