Rodzilla
I have a set of Mahle PowerPak forged pistons and with those came file fit rings but I think somethings not right. The box says 4.070" + .005" which makes sense since I'm .030" over size but the oilng rings is oversize to, the ends butt-up when checking fit in the cylinder. Can I cut/file those down? Aren't they suppose to come under size a bit, my understanding was that file fit only meant the two compression rings?
These Mahles have a three piece oiling ring, the very thin top bottom rings are .015" under size which is OK, but the center square wave ring is the problem. I don't think you can file those, side cutters and file off burrs.
What a pain, I didn't even want file fit, thats what came with my rotating assembly.
On another note, anyone know where I can get a hand full of 5/16 - 18 allen head grub (set) screws made from aluminm or a soft metal? I'm doing the oiling mods at top of this forum section and I can't get a drill to go thru the set screws I have, they are hardened. Or any ideas on a really good drill bit. I've tryed several with next to no luck.
