aengineguy
Well after 4 years of buying 1 lugnut and bolt at a time, I am getting really close. Not fired yet, but give me a little time. Tell me what you think....
1971 Dart Swinger
91 LA block .030 over, zero deck, line bored, Hughes Main girdle
Quite a few oil system mods
Standard Melling pump, not HV
Kevco pan and pickup with larger tube
Scat forged crank
Scat H beams
Icon forged pistons
Edelbrock Magnum Heads fully CNC ported by Hughes, 2.08" intakes, milled back to 58cc chambers. Around 300 cfm @ .600 lift
about 10.65 comp
1.6 good rockers
ARP head and main studs
Hughes Solid Flat I .610, E .614, I 252, E 256 both @ .050, 106 LSA
Solid lifters with EDM holes (yes they are oil thru along with the pushrods)
Air gap with 750 HP holley (may fully port the Gap or go with an M1 single later, 950 Holley maybe later)
TTI 1 7/8 Headers
TTI 3" exhaust to the bumper
SFI Damper and Flex
Mallory #42 dist. with Hyfire 6 box and rev. limiter
Edelbrock 160 GPH pump pulling thru (2) Fram filters
-8 lines to regulator and -6's to carb
Jaz Cell and battery in the trunk
John Cope built HD904 with manual\reverse
Custom 3600 rpm converter
1350 joints
Moser 8 3/4 nodular center section with Richmond 4.10's and Moser Alloy axles
Wilwood Discs up front, Billet Spec. Wheels
Many other supporting pieces.
..........and a Partridge in a Pear Tree!
Really enjoy this forum.....Thanks!
1971 Dart Swinger
Scat forged crank
Scat H beams
Icon forged pistons
about 10.65 comp
1.6 good rockers
TTI 1 7/8 Headers
SFI Damper and Flex
1350 joints
