Backtobasics
The 76 Dart Lite has been down for a month. It has never had acc pump rod. I tried to fashion something, and in the midst, the carb decided it didn't want to idle. I took it apart to blast all the passages, and in the process broke the emulsion tube. It just dawned on me last night to check a spare /6 engine I bought (bought /6 with trans for the /6 bellhousing)
Sure enough, the carb on there is the same architecture has mine. I pulled the top off the spare carb, drilled the mounting holes out larger (my main body was stripped, we drilled and tapped to larger size) and assembled. It went back together with no drama, and idles great, plus I now have accelerator pump. The rod I have needed was in the garage all the time. :cheers:
Test run tonight (did carb and install work late last night):cheers::cheers:
