Finally Picked My Color
Well the mixture that the paint guy put together using that original paint code most definitely had fine metal in it. That is fine with me; it just surprised me because I did not know. It will definitely be eye-popping in the sunlight. And a black vinyl stripe is going on the back and a trunk trim panel across the rear.
The V2 orange has very fine metallic. Its pearl today. It is very hard to see. If you would wax or polish a spot then use a flash light on that spot you should see some fine metallic.
