I plan on wiring my Dart myself. With that said, what to do with the rectangular connector hole that mounted the OEM plug and recepticle. Using a piece aluminum, 3/4" pvc conduit, & plumbing splice, (all cut to size), I fashioned a feed-thru insulator. All will be sanded and painted. This may not be much, but it might help those who are not using the original harness. ( Alas: a techinical break through). You will also need some PVC cement. Howard
