First design vs final design
kellyman
Member
Missoula Montana
I’m in the process of changing my 1967 Barracuda steering column from auto to manual. ( I’m changing the collars)
I also want to replace my broken turn signal switch. It appears to be the first design style. Can I use a final design switch? Are they interchangeable? Seems like they are both the same but I’m not sure. Thanks
How about a photo of both switches?
Looks like both will work. You may have to trim the plastic extension over by the horn contact, but, other than that it looks correct. Both look to have the lane change feature too.
Better pictures of the two designs.
I thought they looked about the same. I’m hoping the final design is a better version. I’m not sure why you can’t still get the first design if the final one is better. Thanks for the reply. I don’t post here often but lots of good info.
