Fitch fuel catalyst
Need some independent research & testing by an independent third-party.
Until then, it's just another "magical" product, like the 3000-mpg carburetor.
Until then, a lot of magazines show what prostitutes they
really are by having such carnival-crap among their pages.
When these people are finally exposed as the frauds they are,
the magazines should be busted and fined big-time also.
Im VERY familiar with it, matter of fact I live less than 1/2 hr from where they are located in Ct. It absolutely does not work. They had aimed their product towards motorcyclist at some point and several of the American bike magazines got their paws on it for a real life test. The dyno results proved less than 1 HP gain. Fuel economy based on several fill and goes showed NO actual gain in MPG. One magazine however found a gain of 5 miles per tankfull, but only after the second fillup. This could be attributed to riding style or terrain, as my RoadGlide gets 41-42mpg around town/commuting and close to 56-60 mpg in overdrive gear on long interstate jaunts.
One of my friends picked one up some time ago, we passed it around between 3 of us for a short time to see if it worked for any of us. I found virtually no difference with my Road King I owned at the time. It was decided it was just taking up space in the tank so he tossed it into a roadside ditch.
They did a dyno test of it on HorsePowerTV & it seemed to work, but I still don't think I'd buy it. I'm way too skeptical.
I saw that test too. The gain in hp and bsfc that they reported was statistically insignificant. Hell, they could've turned down the thermostat in the dynoroom and seen more of an improvement.
Shame on HP TV for showing that swill. Right after the test they ran a loooong Fitch commercial too.
I know they gotta make money but give me break. What's next, fuel line magnets for our race cars?
Frankly, that says a lot more about Horsepower TV than the Fitch Fuel Catalyst. :)
I turned up an interesting bit about metallic fuel catalysts in a discussion on another forum when the subject of copper fuel line came up. It turns out that copper fuel lines have a catalytic effect on gasoline, all right. Trouble is, it turns the fuel into gum and varnish rather than into higher octane gas. I suspect the Fitch Fuel catalyst would do the same thing if it had enough metal to have an effect.
I write some technical articles for the various performance magazines. I was approached by Fitch to write a review on their product last year, told them I wasn't interested for the reasons above. Guess some of us still have ethic's over making a buck!
Glad I ran across this. I didn't know about the Fitch snake oil crap but what caught my eye was how how 64Cuda and RC said they saw HP TV do a test and say it worked. Just this morn. I was watching HP TV and they did a test on some kind of black magic oil additive (forget the name) and their dyno showed a 9 hp and 14 lbs.ft torque gain. Funny how right after that they went to a long commercial for that very same product. I was planning on picking up a bottle if it's cheap and try it. After reading this it'll have to be darn cheap or I'm not going to waste my time.
To me this is like those multi-electrode or precious metal spark plugs. If you needed a tune up, SURE they'll make your engine run better. So would a $1.50 Champion. It's the nice sharp edge that facilitates spark production, not some cosmic shape. (As with ANY tune-up item, if you notice a difference, you waited too long to replace.)
Now, organic chemistry was many years ago, but I somehow don't recall how any metallic compound can modify a hydrocarbon without energy somehow being added to the process. So either the catalyst or the fuel must provide this energy. If the fuel provides this energy, there is less left for combustion. If the catalyst provides the energy it must erode quickly as part of a fairly powerful reaction. Either way it is probably heating the fuel (bad). There are plenty of (heavy) metals out there which have energy to give off, but due to toxicity and/or radioactivity you probably can't get them shipped in the mail. If this Fitch unit doesn't change temperature as fuel passes through it, I'm pretty sure nothing much is happening inside it. If the (conductive) metallic elements are being eroded away and carried off with the fuel, this will just give your ignition system fits.
I'd love to see an actual chemical analysis of the reaction which supposedly takes place. They say this gizmo gives you "refinery fresh" fuel. So does going to a multi-pump gas station on a busy street.
