Rodzilla
I'm posting here as the relevant area has little traffic. So I bought a flaring kit to redo a couple fitting on my pre bent stainless lines that run from master cylinder to the prop valve. A couple of the fittings didn't match for my Wilwood parts. I heated up the line to keep it from cracking while flaring and that worked good. Only problem now is it wasn't double flared. Stainless is way harder material then standard or copper brake lines, will a single flare on stainless be enough without worries? I have read some guys doing 37* flares and using -AN fitting. Mine was a single 45*. Can I safely use like this? Any thoughts or ideas?
