340swinger4spd
I am about ready to repaint my flat black between the two bumps in the hood. What is a good tape to use that won't bleed?
So use the blue for my lines then step off with green then to my masking paper? What is the difference between the blue and green tape?Initial lines do with the 3m fine line blue. Then come off that with 3m green masking tape. Its expensive, but always hold up well for me with no bleed through, and releases easy without leaving glue on your paint.
Yes that is what I use.Initial lines do with the 3m fine line blue. Then come off that with 3m green masking tape. Its expensive, but always hold up well for me with no bleed through, and releases easy without leaving glue on your paint.
Are there rubber grommets or seals that go around the 4" holes in the hood?Thanx for your help. View attachment 1714981506 View attachment 1714981507
Thanks,are they just to keep water from running into the engine compartment since they don't connect to the air cleaner?Grommets . ..
Thanks for the infoThat's my assumption. You can get them on ebay.
