You can use the Scat part number and call Summit and they will sell you the kit. Summit will match anyones prices so tell them you want it for the flatlander price and they will do it without hesitation. Summit charges $11 handling fee and free shipping on every order regardless of what you order.
I bought my Scat kit through my local machine shop because they matched the online prices. I bought the balanced kit but had the shop re-balance it and it was off when they checked it. Pistons and rods were close but crank was quite a few grams off. The shop said the bearing clearances were beautiful right out of the box. The crank had a small indentation on one of the crank journals and had to be sent back. Shop told me it would run for years reliably as it was but since it was new with a flaw why run it like that? Shop thinks Scat will replace without a problem. Should know soon.
What ever you do get a local shop to go over the balance and bearing clearances regardless of which kit you get. I would get the kit unbalanced and have a local shop balance it because Scat is sloppy on the balance so why pay twice. And from what I hear most balanced kits, even the real expensive ones, are off out of the box.
