Time to start on the drum brakes.The crush washers I got with the flex hose there aretwo with the kit should there be 2 or 1 installed I put the two on should i leave it.
Slider calipers require two copper washers. Place one washer on the banjo bolt, put bolt through the hose and place other washer on the side of the hose where it mounts to the caliper.
dam George i wish i had know that at 9 this morning.There are two there and Cindy and i blead the front brakes to day no leakes tho.What wrong with two?:Looks like I am still learning this front end stuff.:cheers:
