B'cuda
I picked up a swap meet flip top lid with better chrome than mine, but the gasket on the back side is cracked and mine is perfect. Is there any way to remove / swap the gasket and spring? Thanks for any help!
I tried for a few minutes, I thought it may have a key way that would line up and release. I'll check that again tomorrow. Thanksi could imagine that is popped in the same way a 710 cap is
have you tried pushing down on it, twisting it and seeing if it popped out ?
I have made a few new gaskets from Viton rubber I can get. You should be able to kind of slip out the old gasket lay it on top of the new Viton, trace and cut. It has worked for me on an oil cap and P/S cap or two.. If you decide to try it PM me. Mike
