nasty69
junior member
any of you guys had any experience with floor coatings..?? gota 2 car garage in my new house and need some info..Ucoat it anygood ?? wats some good stuff?
thanks alot about all the info ed, u apparently to know your stuff. now this shot blasting machine you speak of..how would i get ahold of one. i obvisously don't need to buy one. where could i rent one .. or any other options without draining the banksI have coated numerous floors professionally, and i have never used u coat and have not researched it. I can tell you, if the floor has been sealed, which almost all concrete is unless specifically asked not too, the sealer must be removed. This can only be done with a industrial floor blasting system typically known as shot blasting. This machine will abrade the surface with small steel shot, and is reclaimed with any debris back in the machine. This will leave a profile similar to 60/80 grit sand paper for the coating to adhere to.
If your floor has no sealer a simple acid etch will work, followed by a neutralizing rinse of vinegar and water. This should still give the floor a sand paper like feel. Also the acid is toxic so be careful and use respirators.
With any floor coating it should be 100% solids. I use products from Sherwin Williams, it is called General Polymers. If you need anything more feel free to pm and I will assist in any way I can. Ed
That's the stuff. Average at best.U coat, is that the mail order stuff out of NJ? If it is - stay away, far away...
C
hey tony , your floor looks great, how much did he charge to do your garage?
