HOTRODSATHER
Active Member
Hey guys, about to get started back up on my duster. First thing I have to do is the floor pan.As you can see from the pics its really bad. I know I am looking at some sub frame damage and the rail under the door are pretty bad. I have never done major body work before, can you please give me some advice about how to do this. I am really worried about keep the body straight and all that stuff, also how do I get the new pan in, through the door or back window? I know I have to drill out some spot welds and melt away the seam sealer other than than I am kinda charging into darkness here. I update this thread as I go with new question and such. The idea I have is to remove the pan, clean all the metal reinforce the welds and joints primer and rattle can the sub frame(except where I will weld the pan to that will just be weld through primer) then once I have it straight tack the seams till I have a solid seam weld,grind it down smooth and POR15 I am looking for the strongest permanent repair I can and I want to add as much rigidity to the body as I can without adding extra steel or structure to it.
Thanks for any help.
