[WANTED] Floor shifter steering column
wsuwrhr
The Masheenist.
Alta Loma
Rating - 0%
0   0   0
Hello.
Looking for a "non-shifter" style steering column for a 69 Dart.
Wanting to put in a 4 spd, V8 and don't need a column shift lever anymore.
Disk brake spindles as well if you have something. Aftermarket lowered available yet?
Let me know what you have.
Thanks,
Brian
Thanks for the heads up!!
Didn't know the P/S and Manual columns are different.
What is different about them? Total length, spline?
Brian
The P/S shafts are extended less than manual. You can usually knock up a manual shaft by screwing with it or jerk out at P/S shaft to fit a manual box..... They do telescope with plastic bushings inside but it does take some effort.
So if I read what you wrote correctly, they are the same, essentially, just the shaft is farther in or farther out, depending on what it is set for.
Brian
Yes the main shaft is a different lenght. I sent a Pm that i have a PS one.
I still have what you need, never heard from you from my PM's I sent
