diymirage
HP@idle > hondaHP@redline
hey guys, last summer i ran over a stump with the plow truck and its made my drivers side running board floppy
this thing is attached to the bottom of the rocker panel, the front and back are pretty floppy, the middle one is still pretty solid
all three of the brackets look pretty much like this
(since mine is a plow truck there is of course a lot more rust)
do you guys think of i put some metal between the bracket and the rocker, and screw it down where it is a little less floppy things will be OK, or is there a better way to fix this?
