7duster4
I noticed a few drips of trans fluid hanging off the speedometer cable for my 904. Is this a common place for fluid to leak? Beneath the cable on the floor was a small spot of fluid from sitting and I assume dripping every so often after a drive. The cable is wet around the area where it goes into the transmission but the rest is dry. Does this mean I need a new cable? Or does it need to be tighten where it enters the trans?
Thanks for any info.
