[WANTED] Flywheel bolts
I've got a set here that came out of the 3sp Demon. 7/16 fine thread with a tad under 7/8 inch of thread. If it were me, on a temporary run stand, I would feel comfortable using grade 8 bolts. I can mail you these, but it may be cheaper to hit the store. For a permanent install, definitely "Flywheel bolts". Let me know if you want me to send them.
Thanks Troy, yeah for breakin only so 2500-3000 rpm max. Bolts will probably suffice.
Thanks!:thumbsup:
