ValiantOne
Hey All,
This is a set of FMJ or B spindles (actually off my personal 76 Cordoba) with pin type caliper/ caliper brackets. Also has dust shields (pretty crusty), calipers (if you want 'em for cores or rebuild), lower ball joint arm (if you want 'em) and most of the attaching hardware. Spindles are driver quality and were working fine on my 'Doba. I did bust off one of the caliper pins in the bracket. There is still enough of the bolt sticking out to get it out. Just use some heat/ penetrating oil, etc.
Is $175 + shipping fair? Never sold these before.
Located in Western MD
Thanks,
CE
Thanks,
CE
