For anyone who has swapped a 340 with manual transmission into a 66 Dart
Here is a photo (looking in from the driver side wheel well) showing the 67 and up position of the ball stud mount.
Has anyone modified a 66 or earlier to accept this plate? How did you know where to locate it?
Simple answer you bolt it on. You are going to want to use the correct early A mount for the swap. Save yourself a lot of time and call brewers. that way you can answer all the questions needed in one conversation instead of a thousand posts here.
straying from the stock mount and using/modifying a 67 and up style piece takes a hard turn into modifying and customizing everything else in the whole apparatus. the z, the push rod, the bell mount, all that jazz.
which you then start veering into no-mans land.
getting a 4spd into the early cars it hard enough as it is, and dicking around with a mish-mosh of parts is just inviting headache after headache. and some ballaches for good measure.
Just locate the stock Z bar bracket in the correct place, mark and drill the holes and bolt it on. What's the issue?
So if I get this part from Brewers, and I swap it for the existing part, the 67 pieces will bolt up?
No.
You're not going to use '67-up parts, you're going to use '64-'66 parts. The '67 and later parts are a completely different arrangement. They don't interchange, so put those out of your mind.
The factory bellhousing for your car was a cast-iron unit for a 9.5" clutch. If you're trying to use a later 10.5" bellhousing, that's another reason to call Brewer's. They have the engine-side ball stud and anything else you'll need to make the later, large bellhousing work with the 1964-'66 parts. They can even advise you on the required floor modifications. They're very helpful, friendly folks who can tell you, and provide, exactly what you need to get your 4-speed dialed.
No.
I am using the 10.5 bell. OK, so the modification is on the bell side not the frame side. I'll get hold of Brewers tomorrow. Thanks!
No, it's everything. The '67 plate isn't made to fit an early-A, the part 66Dartdriver posted is the body ball-stud bracket assy., & You need an early-A Z-bar/rod. Early-A's are ~2.5" narrower front frame rail-to-rail, which makes it ~1.25" short on that side, hence the links posted above.
He doesn't have a stock anything for a '66, He's trying to stick '67 parts in a '66......
Hey guys, here's some closure on this thread. The car is an original 4 barrel/4 speed car that just received a 340. Due to the additional power/torque I installed the 143 tooth flywheel and 10.5" clutch which requires the bigger bell. The only part I could reuse was the fender-side Z bar mount.
To make a long story short, Brewer's Performance does sell all the clutch linkage parts needed to make the swap. Dan was super helpful, to the point of fabbing me up a Z bar on the spot. I've attached some pictures & a parts list for the swap.
Appreciate the input!
Hey guys, here's some closure on this thread. The car is an original 4 barrel/4 speed car that just received a 340. Due to the additional power/torque I installed the 143 tooth flywheel and 10.5" clutch which requires the bigger bell. The only part I could reuse was the fender-side Z bar mount...
Pretty sure you mean 130 tooth flywheel.
