66340SEDAN
FABO Member #3649
Not an A-body but figured I would try here...2001 Dodge Intrepid ES, 2.7 V6, auto trans. The engine is bad or needs work, found coolant in the oil but it didn't overheat, not sure the problem but I don't have time to fix it. Trans good, tires are almost new, newer brakes and battery, new trans shift cable, new driver window regulator, 1 new ABS sensor have all been installed. Body is in great shape, no rust or dents, paint still decent. All glass good, Interior is nice but needs a little cleaning, non-smoker, power everything, ice cold A/C. Everything worked perfect before the engine issues happened. Last time I tried to start it it did run but sluggish. A few years back a new timing chain was installed, this would be worth pulling off the engine if replaced, these always went bad.
Plenty of pics, I can get more, car is dirty but will clean up good. I have a good, clean MN title for it. I am in central MN, 1 hr from the twin cities. This is a nice car, just needs some work. Thanks FABO!! :toothy10:
