66340SEDAN
FABO Member #3649
For sale: used pair of trunk hinges, part number 2520430 on each, should fit 64-66 Cuda. One is nice, moves free, the other has a small crack by one of the bolt holes but is not thru all the way, could be welded or fixed? Looks like it is slightly bent, hinge is pretty tight. So one appears to be good, other needs a little work or could probably be used as is. These are getting harder to find. $20 plus shipping to your USA door. I am in central MN, thanks FABO!!
