dartcuda1
67 Barracuda 500ci 6sp
- The best standard port location head available for competition big-block Chryslers
- Intake ports are raised .650", exhaust ports are raised .250" for improved flow
- Will fit Edelbrock Victor manifolds for both high and low deck engines
- Sold without springs or retainers; use recommended springs to match your cam
- Can be machined to match Max Wedge ports Combustion chamber volume75ccIntake runner volume280cc (Raised .650")Exhaust runner volume100cc (Raised .250")Intake valve diameter2.20"Exhaust valve diameter1.81"Valve stem diameter11/32"Valve guidesManganese bronzeDeck thickness5/8"Valve spring diameterN/AValve spring maximum liftN/ARocker studN/AGuideplateN/APushrod diameter3/8"Valve angle15°Exhaust port locationRaised .250"Spark plug fitment14mm x 3/4 reach, gasket seatMade InUSA
