Force 10 aluminum brake master cylinder
A little help for you since you linked their home page. I assume this is what you’re referring to.
That one is good if you have a power brake booster or like a rock-hard pedal! You may want to consider a 15/16 bore master cylinder. A little more pedal travel but much better braking! Just my 2 cents.
i guess my question would be why do you want a 1 1/32" master cyl?
for the alum. body? more feed back on a power brake car?
I have a manual brake Kh disc front 10x1 3/4 rear brakes and a 1 1/32 master and I have 2 " of pedal now.
I am rebuilding the calipers and thought if the aluminum master is the same size I would change it out also.
if you're find with the pedal feel now, then by all means. a 15/16" or even a 7/8" might give better action if that's what you're looking for.
personally, i've found the 15/16 to be about the sweet spot on disc/drum cars on both manual and power applications.
All other things being the same.
( and assuming I did the math right)
15/16 piston is 12.1% less force than 1" piston
1 1/32" piston is 6.4% more force than a 1" piston
For most of our cars a 1 " piston is stock.
I have a 70 with manual Kelsey Hayes up front, drums in the rear and a Dr diff 15/16 aluminum master. Excellent feel and good braking.
I have an aluminum 1-1/32" bore master on my 68 GTS with SSBC aluminum calipers in front on KH style replacement rotors. Rear brakes are stock. It stops excellent from over 130.
Yes that is correct.
Do you have a force 10, Dr diff or late model store bought? I like my firm pedal and it is not hard to apply brakes at speed also.
