Wasn’t an abody but a Ramcharger. Electric fuel pump with no pressure regulator installed, direct to the carb. It did run, but I’ve never seen a motor smoke like that before and had a rod knock. Bearings were all washed out.
No offense, but we're you drunk when you posted this?Back in the day , folks put sbc in fflords because the block of a sbff is 5" longer than a sbc . Also sbff had different firing orders depending on the year of the engine . Very confusing . Sbff's also had oil pans with different sumps depending on year, make , model or color (lol). Again , depending on year the balancer/flex plate issue comes up . I saw a 34 Plymouth rod for sale and asked the owner why it had a sbc motor . His r esponse was "I wanted something dependable " I said to him , " So , 16 million small Mopars on the road isn't dependable "? No response ! Why are there no Ford engines in Chevies ? lol, lol
4-through-the-floor conversion from 3-on-the-tree - cut 2 holes in the tunnel, ran the rods 1 hole to the other under the carpet.
what a surprise that was
I don't get it, that's exactly how the factory did it. Hole in the tunnel, although you can kind of call it two because of the crossmember, with the shift rods on the cabin side. Sounds like the only difference is the factory put a 4 speed hump over the top when they were done. But the floor and tunnel was the same, the factory just cut the holes and added the hump.
When I did mine I cut two holes, leaving the floor intact over the top of the crossmember to keep the crossmember boxed. Here's the before picture, the lines were copied from a factory pattern. The four speed hump I bought had been cut around the outer edge, leaving the factory floor pattern still attached. I added the lines for the crossmember to leave it alone, but the outer lines were from the factory pattern.
78 Warlock. All the hot wires under the hood were tied together with a carriage bolt wrapped in electrical tape, laying on the inner fender. It did run but how that truck didn’t burn up is beyond me!!
yes - but without the hump, you get water, mud, snow, all kinds of crap blown/sucked up into the carpet, and the rods rub and catch on the carper - not an ideal situation
Rags left in the motor they put there to scrape the intake gaskets. He bought the 360 2bbl motor out of my plow truck.
Changed the intake and the oil pan to put it in a dart. Brought the car to me and wanted his money back due to low oil pressure.
Being he put an adapter on it I put it on the lift to check the gaskets. This is what I found. Yes he did have an adapter with the standard plate under it. He then insisted they were in there until I reminded him he put a 4bbl intake on and the motor came out of a truck so I knew he changed the pan.
He is a well known member on this site and tried to make amends. but others told me stories of how he talked about me. I gave him many parts free because I felt sorry for him. He had Kids with no money. He cut off his nose to spite his face. I have many better items with pics but this post would go on forever
