Found narrowed dana housing with axles and long studs WIW
RTK_line
San Antonio
I put out an add in the local trader page and someone responded. They have a dana housing with axles he's willing to sell. 48 inches from the ends of the flanges. No gears or carrier but has dodge ends and the axles have sealed bearings and 3 inch studs. I was wondering how much it would be worth?
Depends on a few things.
Is it the exact width you need? Was it narrowed with a jig, and is it still straight? Good penetration on the welds? What kind of axles? Also check housing for wiped out side bearing saddles, some don't bother checking before they throw time and money at it.
What axles? Aftermarket or resplined stockers, 16 spline instead of 30 or 35... lots of variables.
Make darn sure the case has the original caps on it too.
For a good empty case, I'd give $100 for it if it was straight and ends welded on well. Axles are a crapshoot unless you can clearly identify them.
A 48" flange length rear is going to be about 53" total drum to drum.
