BLOCK IS .020 OVER
CLEANED, BORED AND HONED
CASTING DATE 3-12-87
NEW SPEED-PRO #H405P CAST FLAT TOP 9.0:1 COATED PISTONS
NEW SEALED POWER MOLY RINGS
STOCK NODULAR IRON CRANK STD/STD
STANDARD 360 RODS
NEW CAM, ROD AND MAIN BEARINGS
NEW EXPANSION PLUGS
NEW MP .484/.484 LIFT HYD. CAM & KIT #P4120231AC
NEW MELLING HV OIL PUMP AND PICKUP
OEM CAR TYPE OIL PAN
FACTORY CAST CRANK 360 HARMONIC DAMPER
NEW ROLLER TIMING SET
"X" HEADS WITH CRANE SPRINGS, 2.02/1.6 VALVES
STOCK TYPE ROCKER ARM-PUSHROD SETUP
LATE STYLE TIMING COVER
COMPLETELY ASSEMBLED & IN PRIME
ENGINE WILL BE PAINTED YOUR CHOICE OF COLOR
$2,750.00
plus shipping from Edison, NJ 08820
PICKUP TRUCK OIL PAN AND P/U CAN BE INSTALLED
INSTEAD OF CAR OIL PAN AND P/U
Shipping is no problem and depending on location I can meet somewhere or deliver it.
AVAILABLE OPTIONS
TORKER II INTAKE - $150.00
FACTORY OEM CAST IRON INTAKE - $50.00
ELECTRONIC DISTRIBUTOR - $25.00
REMANUFACTURED WATER PUMP - $25.00
M/T CAST ALUMINUM VALVE COVERS - $80.00
STANDARD 360 RODS
NEW EXPANSION PLUGS
$2,750.00
AVAILABLE OPTIONS
