Fresh Rebuilt 318 Tick
CudaRay
Active Member
Wichita, KS
Hey FABO!
I recently rebuilt my 318, used a Comp Cams 260AH-8 with new comp lifters and springs. After I got the mufflers on it, I noticed a slight ticking around cyl 8/6. With a stethoscope, I can hear some tapping/ticking above the valve cover on cylinder 8, but not below it. It does also increase in noise with RPM, which leads me to believe I have a failing lifter.
When installing, I did my best to make sure there were no ridges on the bores, and I had lube on the lobes and lifters, while also dunking the lifter in oil. I did not, however, realize I was supposed to pump them up with a pushrod before install.
The car has a slight miss or is just rocking a bit more than I'd expect at idle, despite seemingly running fine. I did have cyl 5/7 plug wires get burnt by the headers, but have since taped them up and added heat wrap.
My question is, what all should I be doing before buying a new set of lifters (and camshaft if the cam has started wiping)? I figure checking that pushrod and rocker arm would be an obvious start, but I'm still pretty new to this (first engine build) and just need some advice.
If you didn't have the lifters machined by someone and you installed them out of the box, you realistically have almost zero chance of a successful break in.
These parts are circa 2020 or so, also bad QC then? So we're thinking buy another cam/lifters set? Any suggestions on brand when I do buy them?
I’ve given up on flat tappets . Rollers only from here on out.
I would at LEAST do diagnosis. Without that, you never know. Might be something simple. Probably not, but might be. Yes, Comp has had issues ongoing for twenty years or more. If the cam has wiped lobes and lifters, the engine will need to come out and be gone back through.
Yeah I'm going to pull the valve covers tonight and take a look at the rocker/pushrods but if I don't find anything I'll pull the intake this weekend and figure it out from there.
I just want to avoid pulling that dang front cover if I can, but I'm expecting it anyway
Howards Cams sells a quality hydraulic lifter. The last set of lifters I bought were Melling from Delta cams and he refaced them before they were sent out.
C%*# cams has been selling inferior quality parts for some time. The 260 H is a good camshaft for your application.
Pull the valve cover and the distributor, then have a buddy spin the oil pump with a priming tool while the questionable lifter is on the base circle and check that the lifter is pumping up,...or not! you'll know...Then you need to inspect the lobe. And cut open your oil filter.
You can get a bore scope from Harbor freight ($79) to look at the lobe, or pull the intake manifold.
You can get a bore scope from Harbor freight ($79), or pull the intake manifold.
Awesome, I'll have to do that. I have a borescope, didn't think about doing that first instead of pulling the intake.
Oil filter media looked real good after cam break-in, I did use the Lucas SAE30 break-in oil for it.
I remember back in the late 80s a local big performance machine shop was having a lot of Comp cam failures. They blamed it on the zinc reduction in oil, but looking back, I think Comp was having problems back then.
That's good. Hopefully it's something stupid.
Quality of camshaft core, lack of consistent lobe taper and poor quality lifter material along with a blind QC tec. all add up!
It might just be a sticking lifter, which can be removed & cleaned out. No need for new parts. I would check first before getting the shot gun out......
# 6 or 8 cyl? Warm up engine & THEN remove the valve cover. Lay down some rag to collect oil. Using gloves, engine idling, rest your finger on each rocker until you feel/notice a change. That is the faulty one.
This is what I was just discussing with a friend, I'll get this done tomorrow and report back! Definitely cyl #8, tested with a stethoscope. Here's hoping.
