[SOLD] Fresh Rebuilt 360
Matts440
Nampa, Idaho
Located: Riverside CA
Price $2000 prefer local pick up
72 block 360, has been 0.060 over, actually has good thickness still, was pulled out of my dad's ram dually. 10.1 comp, swirl port heads, ports were smoothed, performer intake, milodon water pump, will have new brass freeze plugs installed, doing it tomorrow, mopar purple cam, lost specs was just a cheater cam. Steel crank, has windage tray,Ly rods with KB pistons hyper, balancer and flex plate included since all were balanced together, new police rubber elbow hose, mopar distributor, , will put new cap and rotor, Clevite bearings(main, rods), seal power moly top piston rings, king cam bearings, felpro gasket set. Has a intake oil splash shield, also instead of press in plugs, tapped the front oil passages and put a plug in. Anymore info please IM
That doesn’t look like an RPM intake int the picture?
Engine as you get when bought. Finished the freeze plugs install, champion RN503BC plugs, all stainless steel 3040 bolts (intake,w/p,crank pulley, w/p pulley,thermostat housing,valve cover, oil pan,coil,dist hold down, front cover)
