jhdeval
Ok I am a little confused and need some direction. The service manual says the following:
Removal
(1) Raise the car so that the front wheels are free of the floor.
(2) Remove the wheel cover, grease cap, cotter pin, nut lock and the bearing adjusting nut.
(3) Remove the thrust washed and outer bearing.
(4) Slide the wheel hub and drum assembly off the spindle.
(5) Drive out the inner oil seal and remove the bearing cone.
I understand 1,2 and 3 but 4 and 5 do not make sense to me. I have pulled the drum off several times but nothing but the hub ever came off. Should I be expecting something else? Also O'Reilly has the inner and outer bearing and it includes the race but there is no information about a race is there one?
I realize this shouldn't be hard but I want to do it right and it seems the videos all say something different and there isn't much on front drum brake bearing removal.
Removal
