[Found!] Front Bump Stop Frame Bracket Needed
msmrinc
Active Member
Madisonville, TN
Rating - 0%
0   0   0
I'm needing the two brackets that are welded to the front frame rails that hold the rubber bump stops, facing upwards, for the upper control arms. These brackets were removed from my 67 Barracuda some years back to accommodate a coil-over setup, which is long gone. I'm going back to a stock front suspension and need to put these brackets back on the car. Thanks in advance - Arthur
