Large bolt pattern disc brake swap parts...
FMJ spindles and caliper brackets for 10" rotors
1 set is for slide calipers
1 set is for pin type calipers
each set includes parts pictured for that set
dust cap, tanged washer, nut and lock ring also included
all shields have typical one crack, easy fix (pictured)
new usa made hardware shown included
$150 plus shipping for either set
likely in the $26 +/- a few bucks USPS insured to US addresses
paypal, money order
for slide calipers use 1980 plymouth volare as parts reference, any model (1980 has a better bleeder location)
slide calipers run in the $20-$25 each range, quality pads in the $20-$30 range
not sure on the correct pin caliper application for A body use, there are a couple though.
74 Satellite works for pin type pads.
for rotors, either set, 76-80 Dodge Aspen or Plymouth Volare, any trim level
paypal, money order
