I can check back with you in a couple of days.
I am in the process of rebuilding a 73-76 disc brake system.
I have spindles, calipers, caliper mounts, upper control arms, all the bearings, seals, nuts and bolts.
All that you would need to purchase is your own rotors.
Waiting for the parts to arrive from Rock Auto.
On order are the upper control arm bushings, caliper rebuild kits. New ball joints are currently installed in the control arms.
Keep me in mind if you might be interested in the 73-76 conversion.
Jim V.
hemi71x
