Front fender wells
z_daddy
z_daddy
Naples, Fl
Has anybody removed the front fender wells ?? If so is there anything that has to be done to shock towers ??
Shock towers should be braced if inner fenders are removed. Front frame rails are the thing that will need braced the most though. Look in to snout bars. They run from either the fire wall or even through the fire wall to the cage go out and brace the shock tower on there way down to the front frame rails. Also a good place to mount a motor plate if you want.
